Tmcc58
#1 Posted : Sunday, May 12, 2013 5:42:20 AM(UTC)
Tmcc58
our microwave keeps running after the timer has completed and the only way to stop it is to open the door. if I close the door immediately it will sometimes start up again. It seems if I leave the door open for several minutes, the microwave will remain off after the door is closed.
appliance dude
#2 Posted : Wednesday, May 15, 2013 3:34:30 PM(UTC)
appliance dude
Sounds like you have a bad door interlock switch. I would give them a visual check first then do a continuity check on them.
Simon / APP Team
#3 Posted : Wednesday, May 15, 2013 5:36:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sorry for cutting in.
Most likely the problem is defective control board
Part number: WB27X10655
Here is the breakdown diagram and Microwave parts for GE JVM1430WD002 - AppliancePartsPros.com
Thank you.
Post the results.
Simon.
