Ladona
#1 Posted : Friday, May 10, 2013 12:06:25 PM(UTC)
Ladona
The electronic control panel has no lights, no clock, no ability to set temperature,etc. So basically the oven is not working.
There were no symptoms prior.
The stove top is working fine.
We pulled the back off to make sure there weren't any loose wires, which we didn't find. I can't find any schematics on line that are in anyway helpful. Any ideas?
#2 Posted : Saturday, May 11, 2013 6:02:40 AM(UTC)
Does the oven light work?
If not then it may be a power problem.
If yes then odds are that the control board/timer is taost.
