The electronic control panel has no lights, no clock, no ability to set temperature,etc. So basically the oven is not working. There were no symptoms prior. The stove top is working fine. We pulled the back off to make sure there weren't any loose wires, which we didn't find. I can't find any schematics on line that are in anyway helpful. Any ideas?
Does the oven light work? If not then it may be a power problem.
If yes then odds are that the control board/timer is taost. |
THIS FORUM IS DEAD!!!!!!! |
