novelistwendy
#1 Posted : Sunday, February 3, 2008 3:25:38 PM(UTC)
novelistwendy
I was given this dryer from a friend and when I brought it into the house I broke the post on the timer. I replaced the timer, but forgot to write down which wire goes to which post. I have contacted GE and they will only send someone out to fix it, and my friend doesn't have the manuals anymore. Does anyone have this information or can your help me find where to get it? Thank you
#2 Posted : Monday, February 4, 2008 1:53:53 AM(UTC)
You have three contacts in a row on the timer. Trace the wires, the middle wire is usually the power wire, and it should be yellow and thick, that one goes in the middle terminal. Now check the dial for a cool down period, turn timer to it, usually near the end of the cycle. You should now only have continuity between the yellow wire and one of the other two terminals, your motor wire goes there, usually blue. The red wire now goes to the other terminal.
The other wire goes to the left over terminal.
There is only one phase of power to the timer so it is difficult to cause a short if you mis-wired, however, before turning power on, verify with an ohm meter, that you don't have a short across the L1, L2 power lines.
Also, these wires should naturally be near the correct terminals as they usually set up or have a permanent bend.
timer wiring (Dryer Repair)
by richardbecker 9/21/2014 6:34:47 AM(UTC)
Timer Wiring (Dryer Repair)
by Rob NY 2/19/2014 10:54:05 AM(UTC)
Dryer Timer Wiring Schematics (Dryer Repair)
by DVO1978 12/13/2013 11:31:20 AM(UTC)
Maytag Timer Wiring (Dryer Repair)
by Big Boy 1/22/2013 9:31:40 AM(UTC)
Defrost Timer Wiring (Refrigerator & Freezer Repair)
by Will D 5/30/2012 3:44:58 PM(UTC)
483212 defrost timer wiring (Refrigerator & Freezer Repair)
Belarus silverbay 11/5/2011 12:41:05 PM(UTC)
Whirlpool timer wiring change? (Washer Repair)
by patbob 10/17/2011 2:51:12 PM(UTC)
Timer Wiring Diagram (Dryer Repair)
by jmalone34 2/7/2011 10:05:40 AM(UTC)
timer wiring problems (Washer Repair)
by juteck 11/28/2010 7:15:59 AM(UTC)
by justn1978 7/20/2010 1:01:48 PM(UTC)
GE DBXR453ET3WW timer wiring help (Dryer Repair)
by Snowboarder81 12/16/2009 12:57:46 AM(UTC)
Whirlpool Dryer Timer Wiring (Dryer Repair)
by leeke02 9/11/2009 4:09:39 AM(UTC)
