This unit has had a recent repair. The pump was replaced about 2 months ago because it failed. Now, the machine produces ice, however it will randomly not fill the reservoir with water and the pump will cavitate. If I turn the unit off then back on it resets and works fine for awhile that then the cycle repeats.
Any thoughts?
Model number is not correct.
Apparently, Kenmore left some numbers off of the sticker. I crossed referenced the pump that I recently replaced. The complete model number is 10689482998.
