BrinsonServices
#1 Posted : Monday, April 29, 2013 6:25:15 AM(UTC)
BrinsonServices
This unit has had a recent repair. The pump was replaced about 2 months ago because it failed. Now, the machine produces ice, however it will randomly not fill the reservoir with water and the pump will cavitate. If I turn the unit off then back on it resets and works fine for awhile that then the cycle repeats.
Any thoughts?
ApplianceJunk
#2 Posted : Saturday, May 4, 2013 7:41:42 AM(UTC)
ApplianceJunk
Model number is not correct.
BrinsonServices
#3 Posted : Monday, May 6, 2013 12:29:30 AM(UTC)
BrinsonServices
Apparently, Kenmore left some numbers off of the sticker. I crossed referenced the pump that I recently replaced. The complete model number is 10689482998.
Guest (4)
