Hanne555
#1 Posted : Sunday, April 28, 2013 5:24:50 AM(UTC)
Hanne555
The knob for the oven no longer "cliks" off. It seems to turn off, but 5 minutes later (or less) the oven comes back on.
It feels like there is something loose preventing the "click" when turning the knob, to shut off.
The burners all work well.
Can that be fixed?
I do not know how old the stove is as it is a hand-me-down.
#2 Posted : Monday, April 29, 2013 4:33:09 AM(UTC)
Your model number seems to be missing several digits at the end.
Here is what comes up if I use the model number you gave.
Parts for JBS15 - AppliancePartsPros.com
You will have to find the correct unit in the Matching Model Numbers section.
Sounds like you need a new oven control thermostat.
Hanne555
#3 Posted : Monday, April 29, 2013 4:47:51 PM(UTC)
Hanne555
There are several Thermostat/control parts.
Control Panel & Cooktop parts for GE JBS15F1WH - AppliancePartsPros.com
#3 Control element
#14 Thermostat clip
#14 Thermostat
#s 14 show the part I believe it to be, so which one do I need?
Also, how do I get the black cover off? (where the knobs are attached)
#4 Posted : Tuesday, April 30, 2013 6:18:31 AM(UTC)
The oven control thermostat is Thermostat item 14
[COLOR="Blue"]Also, how do I get the black cover off?[/COLOR]
I do not know.
Try Posting using Post New Topic and with luck someone will reply who has done one recently.
Include the correct model number.
