KevinLee
#1 Posted : Thursday, April 18, 2013 1:49:20 PM(UTC)
KevinLee
When the lower bake element is removed and the two wires disconnected, what voltage should be present when bake is selected along with a temperature? Would I expect to see 240Volts?
What should the resistance level be for a bake element number 308180?
The replacement element looks to be a smaller diameter is this typical?
Simon / APP Team
#2 Posted : Thursday, April 18, 2013 2:26:37 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Kevin.
Unfortunately the model number you posted doesn't come up. Please check it and re post.
Simon.
Simon / APP Team
#3 Posted : Thursday, April 18, 2013 2:56:36 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I was able to find a range model very similar to yours.
The voltage may be 230-240 VAC.
The rated resistance of the bake element is about 22 ohms.
The diameter may vary depends on the manufacturer.
Simon.
KevinLee
#4 Posted : Friday, April 19, 2013 1:58:46 AM(UTC)
KevinLee
Thanks. The resistance I measured was 22 ohms. As I am not obtaining 220 Volts at the element, I will need to check the rest of the circuit.
