When the lower bake element is removed and the two wires disconnected, what voltage should be present when bake is selected along with a temperature? Would I expect to see 240Volts? What should the resistance level be for a bake element number 308180? The replacement element looks to be a smaller diameter is this typical?
Groups: APP Team
Hi, Kevin.
Unfortunately the model number you posted doesn't come up. Please check it and re post.
Simon.
Groups: APP Team
Hi.
I was able to find a range model very similar to yours.
The voltage may be 230-240 VAC.
The rated resistance of the bake element is about 22 ohms.
The diameter may vary depends on the manufacturer.
Simon.
Thanks. The resistance I measured was 22 ohms. As I am not obtaining 220 Volts at the element, I will need to check the rest of the circuit.
