Hello. I have a whirlpool duet washer that has is giving me a error code FH I had ran the diagnostics and I received code C:05 please help. Thanks everybody.
Hi Ben, Check the pressure switch as described in the attached file. Male sure the pressure hose connected to the switch is clear. - The pressure switch Part number: W10514214
