Ben rodriguez
#1 Posted : Monday, April 15, 2013 6:15:13 PM(UTC)
Ben rodriguez
Hello. I have a whirlpool duet washer that has is giving me a error code FH I had ran the diagnostics and I received code C:05 please help. Thanks everybody.
#2 Posted : Tuesday, April 16, 2013 4:36:12 PM(UTC)
Hi Ben,
Check the pressure switch as described in the attached file. Male sure the pressure hose connected to the switch is clear.
- The pressure switch Part number: W10514214
- The pressure hose Part number: W10004260
File Attachment(s):
Testing pressure switch.doc (334kb) downloaded 20 time(s).
whirlpool duet error code FH (Washer Repair)
by misterfixall 1/11/2009 10:36:01 AM(UTC)
by misterfixall 1/5/2009 10:49:21 AM(UTC)
