Stevegefridge
#1 Posted : Monday, April 15, 2013 2:57:36 PM(UTC)
Stevegefridge
Hello I have refridgerator listed above
The freezer makes a horrible sound when running, today when I came home I couldn't take it anymore. I removed three plastic pieces that go around a fan in the freezer. I can see that the fan wobbles a little bit if I out my finger on too of the pin that goes thru the fan (and stabilize it) it stops the sound.
I called GE $85 to come and look at it. I'm kinda handy and don't have the money to have someone else do it as I recently bought my first home.
Any idea what I need to replace?
Freezer and fridge are nice and cold. Just horrible sounds when running. Like the plastic fan is bumping into the plastic housing. Surrounding it.
Thanks!
Simon / APP Team
#2 Posted : Monday, April 15, 2013 3:35:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi..
If you don't see anything loose, most likely you should replace the evaporator motor and fan blade (## 610,613 on the diagram).
Here are the breakdown diagrams and Freezer Section parts for GE GTL22JCPDRBS - AppliancePartsPros.com
Post the results.
Simon.
Freezer repair help (Refrigerator & Freezer Repair)
by reggier 12/31/2011 1:58:48 PM(UTC)
