Sawojt
#1 Posted : Sunday, October 4, 2009 5:50:21 PM(UTC)
Sawojt
The dishwasher doesn't clean the dishes and after a cycle the soap dispenser has half the soap left in the compartment. The interior of the washer has residue or soap film troughout.
The washer runs through the entire cycle yet it seems that it takes 20 minutes longer than it did before.
When the diswasher discharges into the side outlet of the garbage disposal I can feel that the water is luke warm at best.
I know this washer has a food chopper or disposal in it.
Is it possible that the water flow is has less pressure because it is clogged? Or could it be the element is bad? How can I check?
Thanks, Stephen:rolleyes:
#2 Posted : Monday, October 5, 2009 5:28:48 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
Sounds like a low water problem or pumping problem.
First I would check that the unit is getting enough water. Tech sheet says it should fill to just above the filter screen. If not the filter screen on the input side of the water valve may be partially clogged.
Next I would check/clean the pump filter etc. see the tech sheet.
When the dishwasher discharges into the side outlet of the garbage disposal I can feel that the water is luke warm at best.
If the water is low or not pumping correctly it will not heat up properly. This will also extend the cycle time
Yes
Doubtful that this is the problem because even cooler water should flush out the soap from the dispenser.
How can I check?
Heater and hi-limit thermostat can be checked with a meter.
Sawojt
#3 Posted : Tuesday, October 20, 2009 8:16:03 AM(UTC)
Sawojt
Well you were correct! The chopper assembly was in pieces so the pump wasn't sending water through at all.
Since I changed the chopper we have full force water pressure & the soap dispenser is completely clean.
When the water drains into the disposal it is warm, not hot. We run the hot water a few minutes before we begin a wash.
There is also a little soap residue on the dishes.
Any thoughts on this?
Thanks, your help is greatly appreciated.
#4 Posted : Tuesday, October 20, 2009 8:53:27 AM(UTC)
Sounds like the temperature boost is not working.
Check that the heat element os on during dry.
If not remove power from the unit and check the element and the high-limit thermostat.
If it does dry then I would check the thermistor if your unit has one.
kenmore dishwasher 66513043K116 still not draining, after changing drain motor? (Dishwasher Repair)
by thivakaran 12/5/2022 11:47:06 AM(UTC)
Repeating Error 24 on Kenmore Dishwasher (Dishwasher Repair)
by abidh2 12/24/2021 4:45:12 PM(UTC)
Kenmore Dishwasher 665.13733K600 Major Leak Problem (Dishwasher Repair)
by Ken More73 11/10/2021 12:22:29 PM(UTC)
Kenmore Dishwasher - no control lights but washer works (Dishwasher Repair)
by toibn46 10/22/2021 10:08:47 AM(UTC)
Kenmore Dishwasher Keeps Running (Dishwasher Repair)
by VicRattlehead 9/21/2021 1:25:13 PM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Kenmore dishwasher turning on by itself (Dishwasher Repair)
by Guest 5/24/2021 11:06:12 AM(UTC)
Kenmore Dishwasher drain output has stong sulphur smell (Dishwasher Repair)
by Larbo 1/13/2021 3:35:42 PM(UTC)
Kenmore Dishwasher Heater (Dishwasher Repair)
by mikedbom 11/11/2020 4:21:33 PM(UTC)
Kenmore Dishwasher Smartwash (Dishwasher Repair)
by katzman299 1/4/2020 11:02:06 AM(UTC)
Kenmore dishwasher model 665.15113K211 started high pitch sound between cycles (Dishwasher Repair)
by redeyedog 5/10/2019 8:21:48 AM(UTC)
Kenmore Dishwasher control pannel not working (Dishwasher Repair)
by Douglas Scherer 3/14/2019 6:32:33 PM(UTC)
Kenmore Dishwasher fills then drains (Dishwasher Repair)
by qkantaris 1/5/2019 8:39:01 PM(UTC)
How do you install Part W11048936 for a Kenmore Dishwasher (Dishwasher Repair)
by S Hall 3/23/2018 4:46:54 PM(UTC)
Can't loosen impeller part for kenmore dishwasher (Dishwasher Repair)
by rbhall52 9/5/2017 12:04:52 PM(UTC)
