Check windings and ground. Cleaned condenser. Replaced compressor relay and overload relay. Compressor running hot to touch. Slight vibration on compressor. Condenser fan running. Lights on. Also replaced defrost timer. However neither side of refrigerator is cooling. Any suggestions. :)
Since the compressor is running and you are getting no cooling from the evaporator/freezer coils, you have a sealed system problem.
This will be an expensive repair as you need a pro. Often it makes more sense to put those dollars towards a new unit. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Since the compressor is running and you are getting no cooling from the evaporator/freezer coils, you have a sealed system problem.
This will be an expensive repair as you need a pro. Often it makes more sense to put those dollars towards a new unit. Thank you for the advice.
Fridge Runs But Only Cools To 42* And The Freezer Only 28* The Compressor Is Very Hot To Touch.
Any Suggestions
Need Help With My Refrige/freezer Only Cools To 42* & 28*
thank you for the reply but I am getting some cooling from the units coils. The unit cools on the freezer side to 28* then shuts down and goes to 40*. when it shuts down I touch the compressor and it is very hot. Do you believe I still have a sealed system problem? What does that mean exactly?
BILL 3RD
I will reply on you other post it will be less confusing than adding to this one where the fellows problem seems different to yours. |
