aJohn
#1 Posted : Saturday, April 13, 2013 2:16:00 PM(UTC)
aJohn
Check windings and ground. Cleaned condenser. Replaced compressor relay and overload relay. Compressor running hot to touch. Slight vibration on compressor. Condenser fan running. Lights on. Also replaced defrost timer. However neither side of refrigerator is cooling. Any suggestions. :)
#2 Posted : Sunday, April 14, 2013 5:55:12 AM(UTC)
Since the compressor is running and you are getting no cooling from the evaporator/freezer coils, you have a sealed system problem.
This will be an expensive repair as you need a pro.
Often it makes more sense to put those dollars towards a new unit.
aJohn
#3 Posted : Sunday, April 14, 2013 6:03:43 AM(UTC)
aJohn
Thank you for the advice.
BILL 3RD
#4 Posted : Thursday, August 28, 2014 8:32:12 AM(UTC)
BILL 3RD
Fridge Runs But Only Cools To 42* And The Freezer Only 28*
The Compressor Is Very Hot To Touch.
Any Suggestions
BILL 3RD
#5 Posted : Thursday, August 28, 2014 8:33:46 AM(UTC)
BILL 3RD
Need Help With My Refrige/freezer Only Cools To 42* & 28*
BILL 3RD
#6 Posted : Thursday, August 28, 2014 8:52:56 PM(UTC)
BILL 3RD
thank you for the reply but I am getting some cooling from the units coils.
The unit cools on the freezer side to 28* then shuts down and goes to 40*.
when it shuts down I touch the compressor and it is very hot.
Do you believe I still have a sealed system problem?
What does that mean exactly?
#7 Posted : Wednesday, September 3, 2014 2:58:17 AM(UTC)
BILL 3RD
I will reply on you other post it will be less confusing than adding to this one where the fellows problem seems different to yours.
Guest (4)
