billykid
#1 Posted : Thursday, April 11, 2013 7:30:51 PM(UTC)
billykid
You have been a member since:: 4/11/2013(UTC)
The freezer has ice build up on the bottom of freezer. I turned off ice maker and removed the ice build up. Let sit for 2 days and again ice has started to build up. I noticed the drain on the back of the freezer was plugged.
How or why does the drain get plugged with ice.
I have unplugged water line. Thought I would use some hot water to try and unplug drain.
#2 Posted : Friday, April 12, 2013 1:47:48 PM(UTC)
This problem has nothing to do with the water line. The cause of the problem is a clogged drain. Defrost it and run some hot water through the drain. A turkey baster may help. Make sure the other end of the drain is clean.
upright freezer ice build up (Refrigerator & Freezer Repair)
by zeelad 4/16/2011 8:01:00 PM(UTC)
frost free freezer ice build up again (Refrigerator & Freezer Repair)
by mherskind 5/4/2009 1:02:24 PM(UTC)
Freezer ice build up (Refrigerator & Freezer Repair)
by johnnib99 7/31/2008 4:57:32 PM(UTC)
