dave27
#1 Posted : Monday, April 1, 2013 3:54:30 PM(UTC)
dave27
I have no idea what to test next (see recent repair history below). Since I replaced the evaporator fan motor, the freezer was running 20 F, the refrigerator was fine. Saturday the freezer even went down to 10 F. This morning, 20 F/50 F. I defrosted the coils this evening. I again checked the defrost element ohms (28). I then checked for voltage to the defrost element, using a can of Freez-it to lower the temp of the defrost thermostat. At first I got 64 volts, then with a few more squirts 128 volts. There are two rows of coils in this unit, only the bottom row freezes up. Could there be a restriction in the line?
10/18/12: replace defrost thermostat (clips to coils). Tested bad in ice water bath
3/20/2013: clean condensor coils. Running hot due to apparent ice jam (defrost water found in bottom of refrigerator).
3/22/2013: defrost element reads 28.1 ohms. Replace defective evaporator fan motor (would only turn once you gave the blades a nudge).
3/29/13: replace defrost timer (old one tested good).
4/1/2013: unit not cooling (20 F/50 F). Defrost element reads 28.1 ohms. Appears to be getting voltage (see above).
#2 Posted : Tuesday, April 2, 2013 2:18:09 AM(UTC)
With only a few coils frozen, you have a refrigerant leak/bad compressor.
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 11/17/2012 11:44:40 AM(UTC)
GE Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by Steph Paine 10/28/2012 12:36:56 PM(UTC)
GE refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by t38263 5/29/2012 7:29:13 PM(UTC)
GE Refrigerator/Freezer Not Cooling Enough (Refrigerator & Freezer Repair)
by eguerns 10/18/2009 6:54:53 AM(UTC)
