carwade
#1 Posted : Saturday, October 3, 2009 5:24:01 PM(UTC)
carwade
The "High Temperature" light is flashing. Cannot get any of the other buttons to work. Start button does not work either. The only other button that lights up is the Normal Cycle button, but it will not stay lite up. Can you help?:confused:
#2 Posted : Sunday, October 4, 2009 9:59:50 AM(UTC)
Could not find info on a XTP11, the following tech sheet is for a XTPQ1.
Hopefully they are the same
http://www.servicematters.com/d...0Sheet%20-%208535451.pdf
A flashing key is often a stuck key.
Remove the ribbon cable from the control pad and check that the key opens and closes with a meter.
If it does not open then the keypad must be replaced.
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
GE Profile Refrigerator - door control panel problems (Refrigerator & Freezer Repair)
by BenAllen13 10/15/2016 6:49:09 AM(UTC)
ge Microwave Control Panel Problems (Microwave Repair)
by bgrose 8/11/2013 6:13:00 AM(UTC)
diagnosing a user control panel problem (Washer Repair)
by Hoser2113 5/3/2013 1:32:07 PM(UTC)
Kitchaide Key/Control panel problem (Dishwasher Repair)
by jeremyracine 1/7/2012 2:07:58 PM(UTC)
DW Control panel problem (Dishwasher Repair)
by JCBryant 11/28/2011 7:16:42 AM(UTC)
Magic Chef Control Panel Problem (Oven Repair (including Ranges and Cooktops))
by m4p 6/2/2011 12:13:46 PM(UTC)
control panel problem (Oven Repair (including Ranges and Cooktops))
by jerry10 2/17/2011 4:35:39 PM(UTC)
Control Panel Problems (Dishwasher Repair)
by robinsdillon 2/9/2011 2:10:16 PM(UTC)
Magic Chef Range Control Panel Problem (Oven Repair (including Ranges and Cooktops))
by gnit2000 1/9/2011 1:30:17 PM(UTC)
Whirlpool Gold GY398LXPS00 Oven control panel problem E0F2 (Oven Repair (including Ranges and Cooktops))
by kinderguard 9/13/2010 9:12:24 AM(UTC)
Neptune control panel problem (Dryer Repair)
by Greggy H 8/25/2010 5:21:25 PM(UTC)
Control Panel problem (Oven Repair (including Ranges and Cooktops))
by Stick7575 12/22/2009 11:38:33 AM(UTC)
by chrisingrandmarais 12/9/2009 1:45:05 PM(UTC)
Control Panel Problems for Maytag Dishwasher (Dishwasher Repair)
by tommyboy84 11/23/2009 9:43:06 PM(UTC)
