mjrobinson
#1 Posted : Thursday, March 28, 2013 12:23:12 PM(UTC)
mjrobinson
I opened my freezer door and heard a crackling sound, while investigating the sound I observed red hot coils in the lower rear section of my freezer ( visible with the door open) I immediately unplugged the refrigerator. I did not observe any excessive ice build up.
The next day I plugged it back in it seemed to run for several hours ok. that night For saftey I unpluged it. the net day It started to overheat again. after unplugging the unit and plugging it back in a couple of hours later. it seems to be running ok again.
Any help would be appreciated.
Mike
#2 Posted : Thursday, March 28, 2013 12:53:57 PM(UTC)
You probably have a shorted defrost thermostat clipped to the top of the evaporator. You can order it on this site.
mjrobinson
#3 Posted : Friday, March 29, 2013 8:54:05 AM(UTC)
mjrobinson
Thanks Richappy,
So can I assume that the timer turns the defrost cycle on and the thermostat ends the cycle then? I will order the part. Do I replace that from the rear or the inside of the freezer ?
#4 Posted : Friday, March 29, 2013 12:53:59 PM(UTC)
You pull off the freezer back panel, you will find it on top of the evaporator coils.
KitchenAid Drawer Frig/Freezer Overheating Alarm (Refrigerator & Freezer Repair)
by Guest 10/26/2022 4:09:10 PM(UTC)
