the coupling leaks but sometimes does work. Is there anyway to repair this? And if I need a new coupler and hose ass., exactly how do I access the assembly? Do I take off the top board?
Here are your parts Parts for Maytag MDC4650AWW Dishwasher - AppliancePartsPros.comThe coupler/hose is item 15 in section 01. Click on it's picture for more info on it. Also check out the faucet adapter (item 10) to be sure it is the same as yours. [COLOR="Blue"]Is there anyway to repair this?[/COLOR] There are not any internal parts available for the coupler. You have to replace the entire assembly. Coupler/Hose Removal 1. Disconnect power to the machine. 2. Remove Wood Top, see "Wood Top" removal procedure. 3. Remove Foil Bottom, see "Foil Bottom" removal procedure. 4. Disconnect power cord from the terminal box. I am not sure that this is absolutely necessary. Disconnect the fill hose from the water valve and the drain hose from the drain pump. 5. Remove the wire tie securing the drain and fill hoses to a rib on the tub. Wood Top Removal 1. Disconnect power to the machine. 2. Remove the 2 screws securing the top to the mounting flanges positioned under the top in front. 3. Carefully slide top forward to disengage spacer washers from slots in the rear of the cabinet flanges. Foil Bottom Removal Partial removal of Foil Bottom will allow access. 1. Disconnect power to the machine. 2. Lay down a protective pad. Carefully tilt the unit on its back, onto the protective pad. Remove 2 fasteners on the sides. 3. Partially remove the Foil Bottom by folding down. |
THIS FORUM IS DEAD!!!!!!! |
Thank you so much. I really appreciate the help because it is not obvious how to do it. matt
