The ice maker stopped working, there is a red lite that flashes two times takes a short break and flashes two more times this is continuous I have tried turning it of and on, I tried filling it with water and it made ice cubes but did not eject them, the water dispenser workers ok, we were gone for a few months and the water had been turned off we don't know if this is just coincidence though, or if it may be connected, any help would be greatly appreciated.
Groups: APP Team
Hi.
If you close the optic door on the left will the LED turn solid? If not - replace the optic controls kit. If yes - then there could be bad icemaker, water inlet valve, frozen inlet tube at the icemaker.
Please check the model number. The one you posted doesn't come up.
Simon.
