Wondering if anyone could help....my dryer seemed not to be drying thoroughly so I replaced the heating element, the single fuse and the thermostat. I turned it on after changing the parts,and the machine ran for 2 minutes and then just stopped. The dryer door light is fine, the light on the dash board goes on but when I press the "on" pad. nothing happens. Did I short something , or is it something else? I do not think there was anything wrong with the way I changed and inserted the new parts. Someone in customer service is going to send a new fuse in case it is a defective part, but I am skeptical. Anyone have any suggestions? Many thanks! Pam
Here are your parts Parts for Amana LEA90AW - AppliancePartsPros.comThe unit may have over heated and blown the thermal fuse. Did you check/clean your vent system when you replaced the parts? Did you check/clean the internal air flow path including the blower wheelwhen you replaced the parts? |
THIS FORUM IS DEAD!!!!!!! |
