grass1973
#1 Posted : Tuesday, March 26, 2013 4:47:04 PM(UTC)
grass1973
Wondering if anyone could help....my dryer seemed not to be drying thoroughly so I replaced the heating element, the single fuse and the thermostat. I turned it on after changing the parts,and the machine ran for 2 minutes and then just stopped. The dryer door light is fine, the light on the dash board goes on but when I press the "on" pad. nothing happens. Did I short something , or is it something else? I do not think there was anything wrong with the way I changed and inserted the new parts. Someone in customer service is going to send a new fuse in case it is a defective part, but I am skeptical. Anyone have any suggestions?
Many thanks!
Pam
#2 Posted : Friday, March 29, 2013 3:18:01 AM(UTC)
Parts for Amana LEA90AW - AppliancePartsPros.com
The unit may have over heated and blown the thermal fuse.
Did you check/clean your vent system when you replaced the parts?
Did you check/clean the internal air flow path including the blower wheelwhen you replaced the parts?
