oldarmy52
#1 Posted : Friday, March 22, 2013 7:56:54 AM(UTC)
oldarmy52
How do you access the pump
Simon / APP Team
#2 Posted : Friday, March 22, 2013 10:42:33 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The drain pump is easily accessible from the front by removing the toe panel, pull up the terminal cover, disconnect the wires.
To remove the pump, push latch on the circular collar and rotate pump CW.
To install the new pump insert it @ 2:00 position and rotate CCW. Connect the wires, clean the water from the bottom and check the float switch.
Simon.
oldarmy52
#3 Posted : Saturday, March 23, 2013 7:46:30 AM(UTC)
oldarmy52
Simon
Thank yo
Ted
Simon / APP Team
#4 Posted : Monday, March 25, 2013 8:44:45 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
