How do you access the pump
Groups: APP Team
Hi.
The drain pump is easily accessible from the front by removing the toe panel, pull up the terminal cover, disconnect the wires. To remove the pump, push latch on the circular collar and rotate pump CW. To install the new pump insert it @ 2:00 position and rotate CCW. Connect the wires, clean the water from the bottom and check the float switch.
Simon.
Groups: APP Team
