roel
#1 Posted : Saturday, October 3, 2009 10:06:35 AM(UTC)
roel
The blower motor will start even if I have the thermostat turned off. I have even disconnected the thermostat at the furnace and the blower motor still will start. Sometimes it will run for a few minutes and sometimes it runs for less than one minute. It will sometimes start up every 30 seconds and run for a short time. I have heard that this model furnace has had trouble with the early circuit boards and this could be the problem. Does anyone have any information on this problem? Thank you
SublimeMasterJW
#2 Posted : Monday, October 5, 2009 7:28:47 PM(UTC)
SublimeMasterJW
Wow a furnace with a mind of it's own. LOL You never hear much about Jenn Air central unit I don't think it is a wide spread problem. You need to check for a stack pipe rain leak dripping on or near that board.
Furnace doesn't respond to thermostat (Heating, Ventilation, and Air Conditioning (HVAC))
by JeffOYB 11/19/2018 11:08:06 AM(UTC)
Coleman Evcom furnace stops, need cool down (Heating, Ventilation, and Air Conditioning (HVAC))
by newkid@north 12/14/2017 8:36:35 PM(UTC)
Furnace will not heat (Heating, Ventilation, and Air Conditioning (HVAC))
by zomalaja 1/3/2017 7:51:36 PM(UTC)
power surge furnace dead now (Heating, Ventilation, and Air Conditioning (HVAC))
by mutineer 9/15/2016 1:53:26 PM(UTC)
furnace won't shut off (Heating, Ventilation, and Air Conditioning (HVAC))
by bowert 2/21/2016 11:19:04 PM(UTC)
furnace not working (Heating, Ventilation, and Air Conditioning (HVAC))
by rebelbob 2/25/2015 3:04:54 AM(UTC)
Furnace blower turning on and off (Heating, Ventilation, and Air Conditioning (HVAC))
by splumer 1/11/2015 8:07:00 AM(UTC)
Lennox G24M series Furnace Story and Questions (Heating, Ventilation, and Air Conditioning (HVAC))
by drcarl 11/21/2014 7:59:29 AM(UTC)
Amana Furnace Condensate Leak (Heating, Ventilation, and Air Conditioning (HVAC))
by LA_Homeowner 11/20/2014 10:02:33 AM(UTC)
Payne furnace blower on all the time (Heating, Ventilation, and Air Conditioning (HVAC))
by vinhn 11/16/2014 12:36:57 PM(UTC)
Furnace blower turns off and on 3 times at the end of the heating cycle (Heating, Ventilation, and Air Conditioning (HVAC))
by guy1 1/28/2014 11:35:22 AM(UTC)
furnace burn smell when heater on (Heating, Ventilation, and Air Conditioning (HVAC))
by johnny wen 12/13/2013 11:43:21 AM(UTC)
Carrier Furnace Doesn't Work (Heating, Ventilation, and Air Conditioning (HVAC))
by Dr_Zoidberg57 11/16/2013 5:26:15 PM(UTC)
Buzzing Sound From Transformer In Furnace (Heating, Ventilation, and Air Conditioning (HVAC))
by lacoppari 10/4/2013 2:45:29 AM(UTC)
Blower problem on a Janitrol GMP 125-4 furnace (Heating, Ventilation, and Air Conditioning (HVAC))
by needshelp2XYZ 7/7/2013 12:49:53 PM(UTC)
