I have diswasher model FDB345LF and ordered door spring 154430501 per the webpage for that model. Upon installing it I found that it is 3/4" longer and smaller in diameter (5/8" versus 3/4" for the original) so it does not fit. It is too long to attach to the lever on the door and any of the holes on the frame. I've attached a photo of the broken original and the 154403501 replacement. Apparently the heavy duty spring 154289301 for this model is the same length. Any suggestions for the correct replacement? Thanks,
Groups: APP Team
Hi.
Apparently, if you use the 154289301 springs they should be the same as the original ones.
Simon.
