The start button will not work on our dishwasher, however all other buttons are working...we are looking for suggestions in what we need to fix? Thanks
Hello,
Most likely the problem is a bad control panel. If you need the correct part number, post the color of it.
Thanks! It is a white dishwasher.
Unfortunately the white control panel has been discontinued. Only black control panel is available. - The control panel Part number: 8573671
