I posted earlier regarding no power to my compressor but di not get any replies. If someone can point me to a wiring diagram for this model, I'll try to figure it out by eleiminating different parts. thanks
THIS FORUM IS DEAD!!!!!!! |
Remove the cover from the motherboard in the back of the refrigerator, pull off the motherboard, and check the back for bad solder connections. if none, you probably need a new motherboard. Call this parts site with the correct model # to order.
