dashah
#1 Posted : 16 years ago
dashah
I posted earlier regarding no power to my compressor but di not get any replies. If someone can point me to a wiring diagram for this model, I'll try to figure it out by eleiminating different parts. thanks
#2 Posted : 16 years ago
GE likes to keep their wiring diagrams a national secret so it is very difficult to find them on the net. This of coarse does keep their techs busy.
Check under the unit to see if they have an envelope in there somewhere, often that is the wiring info.
Here are a couple good sites with troubleshooting help hopefully they will be of some use to you.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
#3 Posted : 16 years ago
Remove the cover from the motherboard in the back of the refrigerator, pull off the motherboard, and check the back for bad solder connections. if none, you probably need a new motherboard.
Call this parts site with the correct model # to order.
Missing GE Wiring Diagram (Refrigerator & Freezer Repair)
by thumbrfg 6 years ago
refridge wiring diagram needed (Refrigerator & Freezer Repair)
by donerightrepair 14 years ago
Thermador Range Wiring Diagram (Oven Repair (including Ranges and Cooktops))
by wybmabiity 14 years ago
