Royale
#1 Posted : Friday, October 2, 2009 7:06:49 PM(UTC)
Royale
The fridge is cold and the freezer is even colder, so those seem to work fine, but the joint where the two side by side doors meet heats up in just a few minutes to a sort of uncomfortable to the touch hot.
#2 Posted : Saturday, October 3, 2009 1:27:06 AM(UTC)
Some units have a switch called econo or miser or something like that, which turns a heater on/off for this section of the frame, check if yours has this and turn it off. It is there to prevent condensation during high humidity.
The most common cause of this is dirty condenser coils or a malfunctioning compressor fan.
Check that the fan is running properly and that it's blades are clean.
Clean the condenser coils.
I clean mine by removing the kick plate and the rear cover.
Rolling it over to an open door and blowing it out with an air compressor.
I have been told a leaf blower also works.
If this is not possible use a brush and a vacuum.
There are long brushes available at appliance parts stores for this.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
