BoxersRule
#1 Posted : Saturday, March 9, 2013 2:45:21 PM(UTC)
BoxersRule
Here is how to wire a WB27T10265 control board when upgrading from a WB27K5273.
Green wire to ground
White split wire to NEUTRAL and OVL2
Black split wire to L1A (COM) to Broil Relay L1B (COM)
Brown wire to OVL1
Gray wire from harness to AUX1
Black wire from harness to AUX2
Purple wire to BROIL (NO)
Yellow wire to BAKE (NO)
COM - Common
NO - Normally Open
NC - Normally Closed
L1 - Typically HOT
See pic for details!
BoxersRule attached the following image(s):
Berdes
#2 Posted : Friday, April 18, 2014 5:12:45 PM(UTC)
Berdes
BoxersRule,
Thank you. I was at the point of throwing the **** oven out.
Your explanation was excellent, and the included picture was
the icing to top it off. Great post. Thanks again.
