Here is how to wire a WB27T10265 control board when upgrading from a WB27K5273. Green wire to ground White split wire to NEUTRAL and OVL2 Black split wire to L1A (COM) to Broil Relay L1B (COM) Brown wire to OVL1 Gray wire from harness to AUX1 Black wire from harness to AUX2 Purple wire to BROIL (NO) Yellow wire to BAKE (NO) COM - Common NO - Normally Open NC - Normally Closed L1 - Typically HOT See pic for details! :) BoxersRule attached the following image(s):
BoxersRule, Thank you. I was at the point of throwing the **** oven out. Your explanation was excellent, and the included picture was the icing to top it off. Great post. Thanks again.
