jackdeecinto
#1 Posted : Wednesday, March 6, 2013 2:52:59 PM(UTC)
jackdeecinto
freezer and refrigerator get cold but freezer does not freeze and refrigerator runs constantly
#2 Posted : Thursday, March 7, 2013 1:42:55 AM(UTC)
Here are your parts.
Parts for Whirlpool ET22DKXFN00 Refrigerator - AppliancePartsPros.com
Check to be sure that the compressor is running.
You can usually hear it but you should also be able to feel it vibrating and it should be warm.
Check that the condenser/compressor fan is running and that the condenser coils are clean.
Check that the evaporator/freezer fan is running.
If all OK remove the cover in the freezer so that you can inspect the evaporator coils.
If they are heavily frosted/iced over you have a defrost problem.
Should be repairable at a fairly reasonable cost.
If there is no frost or just frost in one area (usually where the freon enters the coils) you have a sealed system problem. Be sure to check it after the compressor has run for a couple hours. If you check it shortly after a defrost cycle you will come up with the wrong conclusion.
This will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit.
Here is a good link check out the example pictures, about half way down the page.
http://www.applianceaid.com/refrigerator-not-cold-enough.php
Check the unit's warranty often the sealed system has a longer warranty.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
