swallen
#1 Posted : Thursday, February 28, 2013 5:08:03 PM(UTC)
swallen
Lights on the panel come on but the dishwasher will not start. If we flip the circuit breaker it will start even though the breaker was not off.
#2 Posted : Friday, March 1, 2013 2:22:26 AM(UTC)
I cannot find any info on the given model number.
Tried here and the Whirlpool site.
Please check it.
Sounds like a control board problem.
The4 microprocessor is not resetting by itself but when you remove power from the unit then you manually reset it.
swallen
#3 Posted : Friday, March 1, 2013 2:45:26 AM(UTC)
swallen
That may be a zero instead of an O on the model number. If it is the control board does that mean we would have to replace the whole board and what would be the cost?
#4 Posted : Friday, March 1, 2013 7:36:02 AM(UTC)
Already tried a zero.
swallen
#5 Posted : Friday, March 1, 2013 1:48:52 PM(UTC)
swallen
Sorry, the model is KUDSO3FTSS2
#6 Posted : Saturday, March 2, 2013 4:40:26 AM(UTC)
Parts for Whirlpool KUDS03FTSS2 Dishwasher - AppliancePartsPros.com
I am assuming that everything looks normal after a cycle other than you cannot start another cycle.
Look through the tech sheet in case anything listed there comes up.
if all OK I would replace the control board (item 6 in Control Panel Parts section)
File Attachment(s):
KUDS03.pdf (87kb) downloaded 21 time(s).
swallen
#7 Posted : Saturday, March 2, 2013 2:07:16 PM(UTC)
swallen
Thank you for your help Denman. The PDF wouldn't open but I will check out the control board. That is what we expected.
#8 Posted : Sunday, March 3, 2013 1:07:29 AM(UTC)
I do not know what happened with the tech sheet so here is another try at attaching it.
File Attachment(s):
KUDS03.pdf (245kb) downloaded 13 time(s).
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
