left half dont heat i can disconnect wire at left side and jump hot wire from right side to left and entire element will heat red hot. how can i test broiler/bake select switch and thermostat switch to tell if they are bad?
The model number you posted does not come up. Verify and repost it please.
Gene thats the # on the id tag. the 58ha-2cxw appears to be the same. the ser.# begins with 18c. thanks jerry
thanks Gene. We have decided to replace the stove.
