dirtdobbertwo
#1 Posted : Thursday, February 28, 2013 1:29:36 PM(UTC)
dirtdobbertwo
left half dont heat i can disconnect wire at left side and jump hot wire from right side to left and entire element will heat red hot. how can i test broiler/bake select switch and thermostat switch to tell if they are bad?
#2 Posted : Friday, March 1, 2013 1:31:51 PM(UTC)
The model number you posted does not come up. Verify and repost it please.
dirtdobbertwo
#3 Posted : Friday, March 1, 2013 7:48:24 PM(UTC)
dirtdobbertwo
thats the # on the id tag. the 58ha-2cxw appears to be the same. the ser.# begins with 18c. thanks jerry
#4 Posted : Monday, March 4, 2013 5:05:36 PM(UTC)
This model number is correct. Unfortunately the range is so old that no wiring diagrams and/or electrical schematics are available online. Also the selector switch for the oven is no longer available.
Here are the breakdown diagrams and Parts for Magic Chef 58HA-2CXW Range - AppliancePartsPros.com
dirtdobbertwo
#5 Posted : Monday, March 4, 2013 6:15:45 PM(UTC)
dirtdobbertwo
thanks Gene. We have decided to replace the stove.
