When you set and pull the timer, You can here the time ticking and the washer is humming. Thats it.
Groups: Expert
It's not filling on any temp setting? You hear the timer motor running? Where is the humming?, the motor (bottom of washer), water valves? Will it spin if you set it directly to spin mode?
Eric
