ggm repair & service
#1 Posted : Monday, February 25, 2013 3:21:18 PM(UTC)
Compressor and condenser not coming on, 3 prong connector from inverter compressor
board not getting 21 volts to any of 3 to each other but to ground getting 21
volts to any of the 3 connector contacts.
How many volts to inverter compressor board should there be?
New inverter compressor board and main boards were installed
Thanks Ronson
ggm@luckymail.com
530-545-3711 2-25-13
abadfish66
#2 Posted : Monday, February 25, 2013 11:03:35 PM(UTC)
abadfish66
Check windings of compressor, com-start, com-run and run-start windings should all be the same ohms, if not, the compressor is bad and frying the invertor.
Refrigerator inverter compressor not starting (Refrigerator & Freezer Repair)
by Guest 11/1/2023 4:24:39 PM(UTC)
