I recently found a leak in the white serpentine looking water tank behind the crisper drawer. How difficult is this to replace? The 2 white plastic hoses connected to it are difficult to remove or I don't know the trick. Thanks for any help.
Hello,
What is the end of the model number?
model number is FRS26ZRGWA
Hello, Sorry for the delay. Look for a water line connectors at the tubes. If there are no connectors then just cut both tubes with a very sharp knife and install the new part using the connectors included in the kit. - The water tank kit Part number: 5303918258
