ldanielrrt
#1 Posted : Thursday, February 14, 2013 3:52:50 PM(UTC)
ldanielrrt
I recently found a leak in the white serpentine looking water tank behind the crisper drawer. How difficult is this to replace? The 2 white plastic hoses connected to it are difficult to remove or I don't know the trick. Thanks for any help.
#2 Posted : Friday, February 15, 2013 2:22:20 PM(UTC)
Hello,
What is the end of the model number?
ldanielrrt
#3 Posted : Friday, February 15, 2013 6:55:14 PM(UTC)
ldanielrrt
model number is FRS26ZRGWA
#4 Posted : Tuesday, February 19, 2013 3:41:58 PM(UTC)
Hello,
Sorry for the delay.
Look for a water line connectors at the tubes. If there are no connectors then just cut both tubes with a very sharp knife and install the new part using the connectors included in the kit.
- The water tank kit Part number: 5303918258
