im not sure how to connect the wires i am thinking to connect the three as normal and then just add the green to the green already there but im not sure. jdovas attached the following image(s):
Your model number is incomplete. Kenmore numbers are usually 3 numbers, a period and then another 6 to 8 numbers. If you can get the correct model number, you should be able to get the install instructions off a site called managemylife.
Usually what you do is connect the red, white and black from the line cord to the terminal strip. The current green/yellow wire must be disconnected and taped up so that it cannot touch the frame or another connection. The green from the line cord then attaches to where the green/yellow was attached. |
THIS FORUM IS DEAD!!!!!!! |
