jdovas
#1 Posted : Wednesday, February 13, 2013 7:48:31 AM(UTC)
jdovas
im not sure how to connect the wires i am thinking to connect the three as normal and then just add the green to the green already there but im not sure.
jdovas attached the following image(s):
#2 Posted : Wednesday, February 13, 2013 2:40:49 PM(UTC)
Your model number is incomplete.
Kenmore numbers are usually 3 numbers, a period and then another 6 to 8 numbers.
If you can get the correct model number, you should be able to get the install instructions off a site called managemylife.
Usually what you do is connect the red, white and black from the line cord to the terminal strip.
The current green/yellow wire must be disconnected and taped up so that it cannot touch the frame or another connection.
The green from the line cord then attaches to where the green/yellow was attached.
