ysdc
#1 Posted : Friday, February 8, 2013 7:55:36 AM(UTC)
ysdc
The water spout that dispenses the water from the door is leaking where the line from inside the freezer door meets it. How do I get to it. It appears the panel on the inside is glued.
#2 Posted : Friday, February 8, 2013 3:15:33 PM(UTC)
Hello,
The water line inside this door is not serviceable. The only solution is to replace the whole door.
- The freezer door Part number: WR78X11139
ysdc
#3 Posted : Friday, February 8, 2013 3:45:10 PM(UTC)
ysdc
Hello,
What about the plastic spicket where the water comes out on the front? I believe it attaches to the line in the door. Can you get to it from the front?
#4 Posted : Friday, February 8, 2013 4:44:31 PM(UTC)
You can remove the dispenser front cover and take it apart to see how far you can reach. The instructions are attached to the post.
File Attachment(s):
How to open ice dispenser.doc (97kb) downloaded 2 time(s).
