The water spout that dispenses the water from the door is leaking where the line from inside the freezer door meets it. How do I get to it. It appears the panel on the inside is glued.
Hello, The water line inside this door is not serviceable. The only solution is to replace the whole door. - The freezer door Part number: WR78X11139
Originally Posted by: Gene  Hello, The water line inside this door is not serviceable. The only solution is to replace the whole door. - The freezer door Part number: WR78X11139
What about the plastic spicket where the water comes out on the front? I believe it attaches to the line in the door. Can you get to it from the front?
You can remove the dispenser front cover and take it apart to see how far you can reach. The instructions are attached to the post. Gene.
