Jireh70
#1 Posted : Friday, February 8, 2013 4:20:01 AM(UTC)
Jireh70
Icemaker will not push ice out. It makes ice and if I hold the inner door it will push the ice out but using a cup on the door doesn't work. I believe its a connection issue with the push bar, not sure.
Joe / APP Team
#2 Posted : Friday, February 8, 2013 8:51:24 AM(UTC)
Joe / APP Team
Jireh, You're most likely correct its a linkage or mounting bracket issue. You'll need to access the internal bracket assembly and check for brokrn or damaged components.
Here's a little help.
Good Luck and Thanks,
RF386.pdf (337kb) downloaded 5 time(s).
File Attachment(s):
Binder1.pdf (145kb) downloaded 3 time(s).
maytag icemaker removal, repair or replacement (Refrigerator & Freezer Repair)
by Michael Sledge 11/24/2019 1:48:09 PM(UTC)
calif maytag icemaker in a big drought (Refrigerator & Freezer Repair)
by bruce079 2/27/2014 9:36:52 AM(UTC)
Maytag icemaker stopped working (Refrigerator & Freezer Repair)
by brp3 11/22/2011 5:19:59 AM(UTC)
Maytag Icemaker (Refrigerator & Freezer Repair)
by icaliente 5/2/2011 9:42:40 AM(UTC)
Maytag Icemaker Issue (Refrigerator & Freezer Repair)
by otis44 11/30/2010 6:36:55 AM(UTC)
