mbherbener
#1 Posted : Thursday, February 7, 2013 8:53:50 AM(UTC)
mbherbener
My Whirlpool DU1100XTPBA dishwasher won't fill at all. If I manually depress the button on the float switch, it starts filling. The float itself doesn't seem to be caught or jammed on anything. The float has a pin which goes down through the floor of the dishwasher and (I think) is supposed to press on a little plastic lever, which in turn presses on the float switch - my understanding is that when the float rises, it releases the pressure on the lever and float switch, stopping the fill.
I can't see anything wrong with the float switch, lever or pin individually - but as a group they aren't working. Is it possible for the float switch to go bad in such a way that it needs more pressure to be triggered?
By the way, I started by replacing the inlet mechanism, and it's possible that in trying to diagnose the problem (before replacing the inlet) I managed to misalign or otherwise mess up the float/lever/switch. Anyone have a good set of photos of how they should look?
thanks!
Martin
#2 Posted : Friday, February 8, 2013 1:59:29 AM(UTC)
Parts for Whirlpool DU1100XTPBA Dishwasher - AppliancePartsPros.com
They are the only drawings available as far as I know.
If you click on a part's name/picture often a new page will open with more views and info about that part.
[COLOR="Blue"]
Is it possible for the float switch to go bad in such a way that it needs more pressure to be triggered?[/COLOR]
Yes it can or the contacts in the switch may go bad.
You can often hear the switch click when it closes.
This does not mean that the switch is 100% OK as the contacts may be bad.
If you can push down on the switch's actuator and it click or the unit starts filling then I would replace the switch as long as you rae sure that the float is nice and free.
The best way to check it would be with a meter.
Remove power from the unit.
Remove one wire from the switch. this prevents you from reading an alternate/parallel circuit path.
Check across the switch. it should be 0 ohms.
[COLOR="Blue"]I managed to misalign or otherwise mess up the float/lever/switch.[/COLOR]
As long as the float rides up and down easily it is OK.
Note that sometimes gunk accumulates in it and it and the tubs riser tube have to be cleaned.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
