Parts for Whirlpool DU1100XTPBA Dishwasher - AppliancePartsPros.comThey are the only drawings available as far as I know.
If you click on a part's name/picture often a new page will open with more views and info about that part.
[COLOR="Blue"]
Is it possible for the float switch to go bad in such a way that it needs more pressure to be triggered?[/COLOR]
Yes it can or the contacts in the switch may go bad.
You can often hear the switch click when it closes.
This does not mean that the switch is 100% OK as the contacts may be bad.
If you can push down on the switch's actuator and it click or the unit starts filling then I would replace the switch as long as you rae sure that the float is nice and free.
The best way to check it would be with a meter.
Remove power from the unit.
Remove one wire from the switch. this prevents you from reading an alternate/parallel circuit path.
Check across the switch. it should be 0 ohms.
[COLOR="Blue"]I managed to misalign or otherwise mess up the float/lever/switch.[/COLOR]
As long as the float rides up and down easily it is OK.
Note that sometimes gunk accumulates in it and it and the tubs riser tube have to be cleaned.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
