samcatg1
#1 Posted : Tuesday, January 29, 2013 12:54:03 PM(UTC)
samcatg1
my frig works great for about 1 week then it starts getting warm...I unplug it
for 24 hours and plug it back in and the cycle continues...it has a little
frost inside back of freezer....every thing else seems to working properly..
need help asap
Simon / APP Team
#2 Posted : Tuesday, January 29, 2013 2:05:26 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
When the fridge start acting up, open the rear cover in the freezer and check if the evaporator is blocked with snow.
If it is - unplug the fridge, locate the main control board at the back of the fridge behind the metal cover.
Locate the plug with 3 wires on the left marked J8,J9,J10 and plug J7 pin9 (top).
Remove the 3 wire plug and using the multimeter check resistance between wire J9 and J7 pin9. If you read continuity then the control board should be replaced.
If there is no continuity - check the defrost heater and defrost thermostat from inside the freezer.
If you are replacing the main control board replace the temperature sensor clipped on the top of the evaporator
Part number: WR55X10025
Control board Part number: WR55X10942
Defrost thermostat Part number: WR50X10047
The defrost thermostat mast be ice cold when checked.
The control board will require wiring alteration, refer to the instructions.
Here are the breakdown diagrams and Cabinet parts for GE PFS22SISBSS - AppliancePartsPros.com
Post the results.
Simon.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
