I have a Kenmore Oasis Washer with two problems.
1: the drain pump will not pump water out unless the drain hose is close to the floor. IE into a 5 gallon bucket. I orderd a new pump.
2: The lid lock does not engage. It tries, you can hear it click about 5 times but then errors out. This just started today. The manual states to remove obstuction. There's nothing blocking the path for the lid lock.
